Zum Hauptinhalt wechseln
Panasonic released the CF-29 on January 1, 2004. It was designed to survive the harshest environments US Armed Forces, service personnel, and enthusiasts could throw at it. The Black Hawk CF-29 was released in 2009.
17 Fragen Alle anzeigen
Why is my hdd not booting or showing up?
I have a used Panasonic CF-29. It came with a SATA upgrade and a 80GB hdd. A couple weeks later it stopped booting saying "Operating System Not Present" and the bios wouldn't show anything under Master IDE so I thought the HDD had died. I swapped in a small SSD (128GB) and installed Ubuntu from a live-usb. EXACTLY the same thing happened "Operating System Not Found"
I've traded the SATA adapter, ditto on both drives.
The weirdest part is that no hdd ever shows up in the bios but will be visible later as a partitioned disk when I view it with Parted in Ubuntu. I can format and install Ubuntu to the disk but upon rebooting the same error appears.
Any ideas what could possibly be going wrong?
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
Don't spend any more money on a CF-29, it's not worth it.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Change the hard disk legacy mode in you BIOS and reboot the system. try to install OS with Bootable Disk
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I'm not seeing a hdd legacy mode. Does this bios have a hidden advanced menu/mode like I've seen in other bios'?
von
Have you tried to update BIOS?
von
Antwort hinzufügen
Kris Jensen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,866
