Zum Hauptinhalt wechseln
The first FWD car to be exported to North America by Volvo
7 Fragen Alle anzeigen
Diagnostic unit on 850 GLT
Where is the diagnostic unit on a Volvo 850 GLT 1997? It's not in the same place as my 850 SE. Front right by the washer filler.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Hi, I think this the answer you are looking for. Ralph
http://www.volvospeed.com/CheckEngine.ph...
Second location
http://www.matthewsvolvosite.com/forums/...
War diese Antwort hilfreich?
Bewertung 3
The ODBII connector is under the coin tray in front of the shifter
Bewertung 0
Your newer 850 96&97 will need a obd2 scan tool reader to get the check engine codes. The plug in port is below the ash tray under the coin holder. Your older volvo is an obd1 and codes can be retrieved by a blinking led light.
I think auto zone stores. will check the codes at no charge.
Bob
Bewertung 0
I just found out that on our standard 95 850 GLT wagon the plug in ... is behind the passenger head lamp but they take a special type of reader not just any and under the hood toward the wind shield a sticker will tell you if its a I or II .... so now im off to find one of these special readers
Bewertung 0
Antwort hinzufügen
John Sheppard wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 11,824
