Zum Hauptinhalt wechseln
maglite mini 2 AA Xenon Taschenlampe von maglite
4 Fragen Alle anzeigen
batterey replacement fir my Mini Maglite AA
I did what you said but when I removed the disc there is another
black plastic device that looks like it has to come out the other end because there is a lip holding it in place
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I tried to take the end cap off with two wrenches and it wouldn't budge.
It's now soaking in WD 40 and hopefully that will work.
If not it'll get the deep six!
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Unscrew the cap on the end opposite of the light bulb.
used Ikea AA, after a year, how can get the battery out?
War diese Antwort hilfreich?
Bewertung 1
The answer above, "Unscrew the cap on the end opposite of the light bulb." doesn't answer the original question regarding removing the second piece of plastic under the lightbulb holder. So, no, the question was not answered.
Bewertung 0
You can gently pry that black cap off using a small flathead screwdriver. Under that you’ll see a black piece that holds the bulb in place and the electrical connections. Push that backwards out the end of the tube away from the head.
Bewertung 0
Antwort hinzufügen
rondon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 19
Insgesamt: 1,353
