Zum Hauptinhalt wechseln
The LG Optimus L7 P705 has a 4.3 inch LCD screen and weighs 4.3 ounces. It has a 5 megapixel camera and a LED flash. It houses 4 GB of internal memory with a SD slot that holds up to 32 GB of memory.
16 Fragen Alle anzeigen
restore my phone software
i do have lg p705 and i forget my lock pattern and google account.i did hard reset but i am not able to do hard reset.what should i do to regain my mobile as earlier without doing hard reset?
Ist dies eine gute Frage?
Bewertung 7
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
If your device is rooted, there are various apps you could run to remove the screen lock. Root it, enable adb on your device so your computer could recognize it and attempt to unlock it.
Otherwise just perform a hard reset via recovery mode on your
1. When the phone is switch off , press and hold the VOLUME DOWN key + POWER key with your left hand.
2. When the LED on the bottom of the phone lights up, touch and hold the MENU key with your right hand. You need to do this immediately, before the screen displays the LG logo. Make sure your left hand is still holding the VOLUME DOWN and POWER keys.
3. Then release the POWER key at vibration time.
4. When the LG logo is displayed on the screen, continue to hold the keys for around 2 seconds,
and then release all them at the same time, before LG logo disappears.
5. Leave your phone for at least a minute while the hard reset is carried out .You will then be able
to switch your phone back on.
CAUTION: If you perform a hard reset , all user application and user data will be deleted.This cannot be reversed. Remember to back up any important data before performing a hard reset.
War diese Antwort hilfreich?
Bewertung 5
how to open pattern lock lg p705
Bewertung 2
Yes it will be enternally greatful
Bewertung 0
Antwort hinzufügen
angikar acharya wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 8,734
