Zum Hauptinhalt wechseln
1.6 oder 1.8 GHz Dual-Core Prozessor, 2 GB oder 4 GB SDRAM, 64 GB oder 128 GB SSD
Fan always going how to fix
My fans on my macbook air won't stop turning. They have not switched off unless I shut down the laptop or closed it. Its not over heating, the CPU is 0% and I have tried everything and nothing is working!!
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare:
Why/when/how did this issue arise?
von
Why you want stop turning fans? They must cooling down laptop its okay, or its to loud for you?
von
Einen Kommentar hinzufügen
1 Antwort
The temperature sensor may be faulty ? Try installing a Fan Management App.
http://www.macupdate.com/app/mac/23049/s...
This will give you control of your fan speed but more importantly the temperature of your CPU.
Maybe it just needs a good cleaning to ensure it's cooling down properly.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Unfortunately Fan temperature is OK. Apple Genius ran some tests and also didn't find any problem. I tried to clean it inside and still no result.
von
Antwort hinzufügen
moxno wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 23
Insgesamt: 1,263
