Zum Hauptinhalt wechseln
Ein Android-Smartphone der Firma Samsung, entwickelt für den asiatischen Markt. Unter vielen verschiedenen Modellnummern vertrieben. Erschienen im Dezember 2014.
118 Fragen Alle anzeigen
Why my phone cannot turn off?
y phone was suddenly hung-up when I open my email. I press long press to turn off but it doesn't work. It will not turn-off. How can I solve this one? I try to recharge my phone, it doesn't work also.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 21
28 Kommentare
holding the down volume button and the power button at the same time till the phone vibrates should restart it. if you have it plugged in charging and do this it turns the phone off
von
That was a fantastic clue. works perfect!. Thank You Dude.
von
Wow that really helped me thank you very much
von
worked perfectly. thanks much!!!
von
Amazing advice! Nothing else worked but this did. Thank you :)
von
23 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Press and hold the Volume down and the Power buttons. When the phone reboots, release them.
Regards.
War diese Antwort hilfreich?
Bewertung 33
21 Kommentare:
Dat was really helpful. ..thanks!
von
its working thank you so much
von
its good idea..... thank u .....
von
good job...... i really like u......
von
it's work... thanks
von
16 weitere Kommentare anzeigen
You could remove the battery and this will kill the phone and hope it boots properly when it restarts once you put the battery back in. Hope this helps and good luck
Bewertung 3
2 Kommentare:
in samsung galaxy a5, you cannot remove the battery since the battery is built in.
von
Many, many thanks
von
unplug Charger before Turning off ,,
it turns off and doesn't reboot ,,
When it's already switched off..you can Plug in the charger and it won't turn on..
Works for me Samsung Galaxy j7 OS 6.0.1
Bewertung 0
Hello .. I forgot my lock pattern and when I try to hard reset it .. won't let me turn it off .. it wants the lock pattern in order to be turned off but I don't remember the pattern .. so .. no hard reset, no nothing .
Bewertung 0
1 Kommentar:
Thankyou so much. Totally worked. Only way to power off / shut down your malfunction samsung j 7 prime phone or device. Power & volume - key while its plugged in to charger. Or else it only restarts.
I was so lost, i felt the phone had malfunctions.
Thankyou so much
von
Antwort hinzufügen
Billy495 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 11
Letzte 30 Tage: 25
Insgesamt: 59,902
