Zum Hauptinhalt wechseln
Der JBL Charge kam im Jahr 2012 auf den Markt. Er hat durch Bluetooth und eine 3,5 mm Audiobuchse eine Vielfalt an Anschlussmöglichkeiten. Sein Akku hat mit 6000 mAh eine hohe Kapazität, so dass er viele Stunden lang spielen kann. Außerdem kann er durch einen USB Ladeanschluss andere Geräte aufladen. Ausgeliefert wurde er in den Farben Schwarz, Grün, Grau und Blau.
28 Fragen Alle anzeigen
What model is the replacement battery and where can I purchase?
Replacement Battery for JBL Charge, is hard to find model and where to purchase.
Ist dies eine gute Frage?
Bewertung 9
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Hi Larry,
I've been looking for ages for a battery that will adequately replace the one in the JBL Charge! After some research, I discovered the battery model is AEC982999-2P, which is a 3.7V 6000mAh battery. A quick Google search did not return a replacement that is the same size as the JBL Charge's.
I know it's not a very common site to use in the US, but Alibaba.com is a good place to look! Hope this helps!
Thanks
Joe
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Yup, they have them. But you have to buy a minimum of 500. :(
von
Hi Joe
I have a JBL that's not working at all , what could be the problem?
even when it' plug in still not working. could it be the batteries? when the speaker was working the sound coming out of it was statically and popping. any feedback would be helpful.
von
Not a real answer but my battery failed after 2 months, no receipt just a serial number and rough estimate of purchase time, location was Stanstead airport.
That's all I gave and all I had, 20 days later a new charge 2 arrived, amazing.
Love the model and love the service:)
Bewertung 1
eBay has a few used.
Bewertung 1
1 Kommentar:
I purchased one and installed it and it works fine.
von
Antwort hinzufügen
Larry James wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 3,438
