changing mower deck belt
how to change the belt on the mower deck
Ist dies eine gute Frage?
Remove the belt from engine pulley
There are arms that have retaining pins, remove all of these on both sides of deck.
Pull sideways on arms on both sides of deck and deck is off.
Pull deck out fro. Under tractor
Two pulleys on deck have plastic guards remove them.
The pulleys have spring loaded guides move them and take belt off pulley. (BOTH SIDES )
Clean out built up debris on deck
Somewhere on the deck there is usually a routing diagram route the drive belt
Replace plastic pulley guards
Move deck under tractor
Lift deck put arms on rods etc.
Replace belt on engine pulley, there is a guide here too put belt under the guide.
This may mess up the deck height happened to mine.
Good luck.
War diese Antwort hilfreich?
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 31
Insgesamt: 1,076
