Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Frage geschlossen
iPhone 5 power button not responding
My powerbutton wasn't working properly with clicking, the clip broke.
After ordering a new button I place it in properly and turned on my iPhone again. Unfortunately it's still not working or even worse then it was before, although it clicks again, it's not turning on or off the screen.
What could be the problem that is occuring with my iPhone 5, and how do I fix it.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Before replacing the assembly, try to take apart completely and push back little bent at the upper right cornet where the power button resides. Look closely. There should be a slight bent. If not, there should be some foreign substance deposited or corrosion. Clean that up. Now, get a new assembly from this short link http://amzn.to/1H4Bl2q which is at fraction of cost and replace it on your own again. You will be fine my friend.
By the way, also check out if the power assembly connector port at logic board (quite closer to the upper level of the battery) has some foreign substances inside. Blow it up and resit the cable. You will be just fine. Hope it helps.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks for advising me altough I have trouble understanding what you want me to do with this part:
"There should be a slight bent. If not, there should be some foreign substance deposited or corrosion. Clean that up."
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 116
