installing ram on Dell Inspiron Duo
can ram be installed into this particular laptop?
Ist dies eine gute Frage?
Vanessa Marshall, not above the original 2GB . The max RAM Is 2GB and is limited by the CPU, the Intel Atom N550 only supports a max of 2GB.
War diese Antwort hilfreich?
The RAM can be replaced, however. If for some reason there's a problem with the ram that's installed, you will be able to replace it. But like oldturkey03 said, only with another 2GB stick of RAM.
Vanessa, if you would like step-by-step instructions to guide you through this process, here is a link to the RAM replacement guide. Hope that this helps!
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 273
