Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Frage geschlossen
Should the shield of the A7 CPU be removed to?
Hello Jessa, i have an water damaged 5S logic board. Should the shield of the A7 CPU be removed to? I've heard that that cpu is using les then 1,5 volt + the water dind't came there. Thanks anyways!
And how do i remove those shields without an hot air station or an hot air gun?
I got some heat resistance aluminum tape and a torch lighter. Can i remove it with this if i do it carefully and if i mask the connectors and expossed parts of with some aluminum tape?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Component shield on iPhone 5S logic board is not just a cap as if they are placed in iPhone 4 or 4S. Being said so, for iPhone 5S, you can remove them with a shouldering iron or a heat-gun. You can also remove them with EXTREME PRECAUTIONS by using X-Acto Blades. Some of the types of these blades are quite affordable.
If you cutout any of the components or pulled off some during the process, it's gone. But, there is a chance that you can open the caps up without damaging anything and be able to clean the corrosion of the logic board. Hope it helps. And good luck!
War diese Antwort hilfreich?
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 98
