iPhone not booting after battery replacement
Hi,
I just got an iPhone 5s for a battery replacement (not my first phone, repairing phones for work). After replacing the battery the phone just shows up the apple logo, for 10-15 seconds, then turns black/blue, with backlight turned on, after another 10 seconds it shuts down.
After further inspection I saw, that I damaged the lightning-port-connector next to the battery connector, so I got a new lightning-port-assambly, but after replacing this part, nothing has changed.
Some more testing I've done:
- connecting the iPhone to power source lets it power on, but doesn't boot, too. (even with the broken lightning-port-assambly)
no DFU/Recovery Mode - phone doesn't show up on iTunes/Xcode(see comment below)- display assambly was removed during the battery-replacement
- another battery - same problem
Thanks for your help!
Ist dies eine gute Frage?
2 Kommentare
After a complete dis- and reassembly (all connectors cleaned with isopropanol), the iPhone still won't boot, but is recognized by iTunes. iTunes says it needs a recovery but after doing this, the problem is the same.
von christianschaefers
Mine had the same problem after a battery change. I took it apart 3 times. The third time i removed the thumb button, battery and 3 cables to separate the screen. I looked at the connections and found a little piece of plastic had fallen into one of the sockets. I blew it out and used contact cleaner on all the sockets and plugs. Now she is working good and charging fine.
von went_fishing
