Zum Hauptinhalt wechseln
Released June 2014, identified by model 635.
54 Fragen Alle anzeigen
Bad Power Button Connection on Nokia Lumia 635
I can tell that it won't turn on for this reason. If I plug it in, the screen is still on, and it turns on when I get a notification. I've made this work for a bit by extending the time the screen is on but this massively drains my battery. How would I fix this? It seems petty to take into a phone repair place.
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Did your phone get hit or dropped?
The most probable reason for that seems to be related to the inner pressure point connector of the power button (located right at the motherboard). Take it anyways to a technician: He would probably tell you that it needs to replace the motherboard of your phone, as it the integrated connector it's difficult to solder again (or doesn't have the time/skill/part for it).
Hope it works again!
Narmith
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Narmith!....i have the same problem but I think I dropped it ..how much does it cost to repair it?
von
lumia 635 power baton bord not warking
Bewertung 0
Antwort hinzufügen
gobstopper2 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 965
