My device cannot turn back on
Hi.. i use Huawei Ascend G7 about 6 month. I want turn on my device after suddenly off it cannot turn on anymore. Can you help me?
Ist dies eine gute Frage?
estimado amigo lo primero que puede ocurrir es que la bateria como comunmente decimos los tecnicos esta muerta o sea sin carga necesitaras acudir a un sat y que te reanimen la bateria. la bateria pierde toda su carga si no se utiliza durante un tiempo.
espero haberte ayudado
War diese Antwort hilfreich?
If you try and charge it and there is a red light flashing, it means that the battery is over-discharged, you should probably go to the phone shop and they can help.
hi joselber mejo
kindly translate to English plz
sfdgkjvbnwsv vfweijsfvnw svusfvhsfvkmdfb afoiwefngcv wo sdfkosgsfc nrgoiwretjhdhb sdlkfhSDF neorfghferg sfdpgjszfdh ndlkfgjhwarg bzdb 9sgjdflbm,rgjkn ghkl;gnkgh7gn5fghemlgknsdigndgbndgbv fxhnhnfbn
translated :)
I also am facing the same problem :(
Can anyone help :(
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,104
1 Kommentar
Same problem of my phone
von Banie
