Zum Hauptinhalt wechseln
Made by GM. It's the eighth generation of a land yacht!
24 Fragen Alle anzeigen
Why is my bonneville leaking from the driver side?
Bonneville is leaking what I think is power steering or brake fluid. My wheel gets tough to turn corners.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
You've probably broke a line from the steering rack to the power steering pump or the seal has gone in the pump . Are you hearing a whine, if so get this fixed right away before you burn out the pump. A pump is a lot more expensive than a replacement line. DON'T let your pump run out of fluid.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
if its brake fluid you'll be out of brakes soon so be careful
I wouldn't be driving it until its fixed either way
von
If your finding it hard to steer than you probably need a new pump already
Bewertung 1
Antwort hinzufügen
savage wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 212
