How to make screen flat? (so home button will work)
Hello,
this is the second time i have replace my sisster's screen on her 5c. Everything works but, it doesn't seem like the screen is flat enough to the surface. When you hit her home button it doesn't work. You have to squeeze the phone in tighter in that area then hit the button. I have made sure everything is connected and the screen is as far down as it can go. Is there away to fix this? Am i doing something wrong?
Ist dies eine gute Frage?
1 Kommentar
I checked everything and even loosened the switch...no help. The battery is fine. The button still only works if you squeeze the bottom.
von mvgalloway5
