Zum Hauptinhalt wechseln
Reparaturanleitungen zu haushaltsüblichen Ventilatoren, inklusive Stand- und Deckenventilatoren.
207 Fragen Alle anzeigen
Frage geschlossen
What is wrong with my 42″ Wind Curve® Platinum with Remote Control?
I took it apart to clean it i've done it before but this time i after i put it back together about a minute after i turned it on it turned off. It only turns on when speed is on 3,when you turn it down to 2 from 3 it feels like speed 1.If you turn it from 3 to 1 the fan blade stops. If you turn it from 3 to 1 or 2 to 1 the fan blade stops spinning, but if the blade does not fully stop yet and u turn it from 1 to 3 or 1 to 2 it keeps spinning. everything seems to be fine with it accept the fan blade spinning when or how fast its supposed to. What the heck is wrong with it?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The Switch might be going bad. Unfortunately, unless you have solder experience, replacing the switch would be difficult. Only other thing I could think of is dust/gunk build up around the motor, does the motor feel hot when the device is on setting 1?
If YES: then the fan is still on and again best thing I can say it to try and clean around the motor and put some wd-40 around the gears (make sure its unplugged when you do this) and try not to get any of the wd-40 on any of the electrical components.
If NO: then the switch is faulty and is turning the fan off when on the 1 setting. it will need to be replaced.
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 52
