Zum Hauptinhalt wechseln
Die Apple Magic Mouse ist eine Multitouch-Maus, die von Apple Inc. hergestellt und verkauft wird. Sie wurde am 20. Oktober 2009 zum ersten Mal angekündigt und verkauft.
52 Fragen Alle anzeigen
Batteries are out of energy after about 3 days.
Hi...
About half a year ago, the fluid of the batteries in my Magic Mouse came out and into the Mouse.
Now since about 2 weeks the batteries are out of energy after less than 3 days. Do you have an idea how to fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sounds like you have some corrosion inside of the mouse from the leaking batteries.
Here's the IFIXIT Magic Mouse Teardown to help show you how to take it apart. Sadly, Apple does not offer any parts so if its to far damaged you'll need to find a junker to steal the parts from or get a new mouse.
Using some white vinegar on a Q-Tip wipe down the spillage until you remove all traces of it. Once you do that go over the same areas with distilled water (not Tap!) to clean off the vinegar as you don't want it to cause more damage. Let the mouse dry out and see if that fixed it.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
My batteries are lasting about 1 hour :( I'm going to try this fix to see if it works. Does anyone know if I can substitute distilled water for isopropanol alcohol?
von
You want Vinegar to chemically interact with the alkaloid of the leaked battery. Then you want to use distilled water to neutralize the acid of the vinegar. Then if you think you got to much water inside you'll then want some high grade isopropyl alcohol (85% or better) to act as a dryer to help remove the water.
Just your basic chemistry :-)
von
The trick is to dampen not flood the parts using the cotton swabs.
von
Antwort hinzufügen
AppleMo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 695
