Zum Hauptinhalt wechseln
Herausgegeben im Oktober 2008 / 2,4, 2,53, 2,66, 2,8 oder 2,93 GHz Core 2 Duo-Prozessor
376 Fragen Alle anzeigen
Are there glass removal instructions for the MBP 15" Unibody?
Hi,
are you able to tell me how i have to proceed to remove the glass from the screen in order to preplace it?
Sommetimes , someone tells that you have to warm up a little bit the border of the glass then pull the glass in the corner with a Suction and a small plastic tool by putting it between the glass and the screan , and sometimes we you don't have to warm glass first .
Thank you for your help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
We have that guide for the 13" MacBook Pro Unibody here (steps 15-22). The glass removal is the same procedure as your machine. Once the glass is off, however, there may be a different orientation (especially with screw locations) for further disassembly.
Good luck!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
brice06 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 1,420
