Zum Hauptinhalt wechseln
Samsung's second-generation smartwatch, released in April 2014 and powered by a Tizen-based OS. Model Number:SM-R380.
60 Fragen Alle anzeigen
Samsung gear watch charger is not charging my watch.
My samsung gear watch will not take a charge, don't know wether it's the charger or the watch. I don't think it is the watch because it was working fine when it was charged. How much are the charges?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
1 Kommentar
the contacts on the watch are scraped off. can I order the re64 board
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Same issue...my charging contacts on the back of the watch were worn away. From another thread I learned about the Circuit Writer, a pen that dispenses conducting ink. A drop on each contact and my watch charged again, and the pen was only about $12. Hope this helps!
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
What store did you get the Circuit Writer from?
von
Apologies for not responding sooner! I picked it up from Ama zon, was about $12.
I've used it twice more since I posted this, and my watch is still charging.
von
A follow-up: It's 8 months since I first used the Circuit Writer on my fading contacts, and have used it 5 times, and finally can't get it to charge any more -- I believe there just isn't enough of the original contact left for this hack to work.
So I ordered a brand new (old stock) Galaxy Gear 2 to replace my old faithful. $120 including shipping from Ebay, and it will be here tomorrow.
It was well worth extended the life of my watch by 8 months for $12, and still recommend you try the Circuit Writer trick! Thanks for following along.
von
Where can I send my samsung galaxy gear watch for repair? It will know longer take a charge.
Bewertung 2
the outer case of my gear 2 neo got broken. where can I find a replacement?
Bewertung 0
Antwort hinzufügen
wayne dozier wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 8
Letzten 30 Tage: 36
Insgesamt: 13,196
