will not turn on after having a power outage
my workforce will not power up after a power outage.
Ist dies eine gute Frage?
it has a fuse on the main board that seems to blow easily , if it's completely dead that's probably it , a factory repair costs more than a new printer, don't use the cleaning cycle on these more than once it uses a lot of ink and then clogs the nozzles worse than before
War diese Antwort hilfreich?
How do I find the main board & fuse
Thanks!but where can I find the fuses ?
There is no fuse on the main board
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 5,121
1 Kommentar
It may be a problem with your power cord or outlet, if it is plugged into a power strip or similar secondary power source try plugging it directly into the wall.
von Tyler Momberger
