Zum Hauptinhalt wechseln
Die Wi-Fi Version des iPad Air mit der Modellnummer A1474 ist in Space Grau und Silber erhältlich. Sie enthält einen A7 Prozessor und ist mit 16, 32, 64 oder 128 GB Speicherkapazität erhältlich.
How does the Ipad Air screen replacement digitizer cable fold and glue
Hi Guys
How does the Ipad Air screen replacement digitizer flex cable fold and where does the adhesive on the flex cable stick down? I can't find the information anywhere, would you be able to post a photo how this is done on a replacement screen?
Luke
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
Hello Luke, bend the flex as shown in follow picture and sit it in the right place, check more details here: http://www.etradesupply.com/blog/reason-...
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
thanks for this! i've ghosted two replacement screens thus far. my third and final attempt is at hand. wish me luck.
von
Hi Luke,
It's a bit hard to explain, but the adhesive from the flex cable should end up sticking to the inside of the frame next to the LCD. When you lay down your new digitizer, you will put down the right side first, pushing the digi cable assembly directly down between the LCD and frame.
We have an iPad air video we recently posted, see if it helps: http://www.amazon.com/gp/product/B00DZXY...
Bewertung 2
4 Kommentare:
Hi Josh, Thank you for the information. The link I can see a product for Tesa 4970 , but no video? Luke
von
Whoops, that was the last link I copied. Here is the correct one: https://www.youtube.com/watch?v=2qQn-T-Y...
von
I clicked on the link cuz IM having the same issue and it says video is private.
von
would have been great to see this video. i've broken two flex cables guessing so far.
von
While I've never broken a flex cable I've resigned myself to the fact that an iPad with aftermarket adhesive holding the digitizer in place will never hold together as well as the factory glue.
I inform people of this before starting the repair and when I hand it back I have kapton tape holding the digitizer in place externally. I usually recommend they get an otterbox style of case to help hold it and to hide the tape.
It sucks, but it's better than a broken iPad.
Bewertung 0
2 Kommentare:
Just a little bit harsh aren't you.
If you actually took the time to read my comment you would see that it was referring to the adhesive that is supplied with these aftermarket screens. I've fixed screens after professionals have already fixed them once and I've seen some interesting repair jobs, not to mention digitizers that have fallen off despite the adhesive and globs of glue that they have use to try and secure them in place.
With that being said, how about you add some positive content to this site rather than join just to put down other people?
von
if you use the red double sided 3M tape along the edges of the Digi (as close as u can get it) then just pop some clamps on it and pop it in a dehumidifier for a half hour it should stay down pretty well and if you want to be sure it will never pop out u can use a vacuum sealer that worked very well for me so far
von
Yes, how about actually going to a certified professional in your area, preferably a small business, and then having it repaired. This way you can help power your local economy, instead of feeding some giant corporate machine that helps no one, as well as not make it worse by trying to do it yourself. How about that? And with all due seriousness, if you don't know what you're doing then don't do it, because if you have to ask that question then clearly you are not qualified to be doing this work, and the business that is running this website should also know that and be telling you this as well. I shouldn't even have to be saying this, they should, and they should also recognize that by giving out free information, they're damaging this industry and taking food off the tables of people who do this for a living. Oh but I'm sure they know that too, which is why they should start telling people you should take it to a local small business with certified technicians and have them handle it.
Bewertung 0
What about those of us who cannot afford to pay someone to fix it?
Bewertung 0
1 Kommentar:
Good question, but in that scenario, as to those who cannot afford to pay someone to repair it, they did in fact purchase the product, yes?
And even just setting that aside, it seems to me that those who can afford to take the very high risk of making it worse, or even entirely destroying it, can then certainly afford to pay to have it professionally repaired so that they don't have to take that risk, at all.
von
Antwort hinzufügen
Luke Robinson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 6,728
