Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Got wet and battery is damage
Took the iPhone apart and took the battery out. Plastic that hold the battery to the iPhone broke and I just wanted to know if changing the battery would fix it. I left the phone opened and is still opened. Would the rest of the parts still would work?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
DO NOT PUT IT IN RICE! You are wasting your time doing that.
Clean the board up with a toothbrush and 99.9% isypropyl alcohol, and then rinse in a tub of isypropyl alcohol, this is a basic DIY fix, for more further cleaning, you would have to remove the logic board shields, and use an ultrasonic cleaner.
War diese Antwort hilfreich?
Bewertung 2
Well the best thing to do when the phone gets wet is to put in a box full of rice and let it sit there for a day or two.
And could attach a picture of the damaged parts and the phone.
Bewertung -2
1 Kommentar:
Rice in a salt shaker is OK for breaking up clumps, but as a desiccant just doesn't cut it for electronics. Do some research. Here's what the Apple Community says: https://discussions.apple.com/thread/566...
von
Antwort hinzufügen
dribrahimperez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 87
