Zum Hauptinhalt wechseln
Released May 1, 2012. The first backlit eReader tablet emits a soft backlight for improved night reading. The device is simple to open up, but the components are all connected.
USB port came loose
A few weeks ago, the USB port on my NST Glow came loose. Now, it will not charge at all. Is there any way to fix/replace it?
Ist dies eine gute Frage?
Bewertung 4
3 Kommentare:
Did anyone ever find a replacement USB socket for this device?
von
the loose port connection means I also cannot hard-wire to my computer to download library books. How can I get this fixed?!
von
Where can I buy this port connection?
von
Einen Kommentar hinzufügen
1 Antwort
Carter clavierkid, you will have to disassemble your Nook, here is a teardown and either solder the old port back on or try and find a replacement.
War diese Antwort hilfreich?
Bewertung 0
5 Kommentare:
Can be quite a tricky job. Here is a video I did of soldering a similar port. It may be helpful if you are going to attempt it. https://youtu.be/gaHlbbxbTGs
von
James Soulsby, excellent video. I've been a fan of your work for years. Thank you for joining the great ifixit community.
von
I'll have to find a T5 screwdriver first. I'll go out and find one today. Thanks for the advice!
von
2 of the pins on my USB port have completely broken off. Any advice on where to find a new one?
von
The local iFix shop claims they have replacement ports for other models but not the simple touch with glowlight. Is this really such a special port?
von
Antwort hinzufügen
Ella wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 1,462
