Zum Hauptinhalt wechseln
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Fragen Alle anzeigen
Why my iMac does not Turn ON?
I have been using my imac for a year.
Yesterday I tried to turn on the machine without any success.
I only hear a short noise if I have my ear in the side of the optical drive and after that a fan working (low noise). Nothing else after that, the screen remains off.
There is only one green LED at the lower part of the iMac.
The only way to turn off the fan is by forcing a shut down with the power button.
The aforementioned LED remains off after shutdown.
I removed the power cable, check the source voltage, tried another outlet without any luck.
Help please. Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
+ well asked
von
Do you know where I can find the Power supply and the Part Number? (I am assuming that the logic control board is OK)
Thanks for your help.:-)
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi, Here is a link to another answer that explains the LEDs. Based on what I see I think you may have a power supply problem. Good luck.
LED power supply and logic board tests
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
+ nice link ;-)
von
Antwort hinzufügen
JRD wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 5,153
