Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
After drop, battery life extremly short and wifi grey out iPhone 6
My iPhone 6 was dropped fairly hard. Everything works like normal except my wifi icon is greyed out and even with a full charge the battery will die within 20-30 minutes of setting it down, if even that long. I have opened the phone and cant see any physical damage to the battery or antenna. I am capable of replacing parts myself but im afraid I dont know which parts are needed.
Please help and thank you in advance.
P.S. the phone is network locked.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
got the same problem
von
Einen Kommentar hinzufügen
2 Antworten
Hello Nick! i can help you with the wifi, what is most likely happened is that the wifi anetenna had a big shock of the fall, and might been "jumped" out of it socket, but i have only experiensed this at Iphone 4/4s.
for the wifi antenna see HERE & HERE
i would've changed both the antenna it self, and the cable just to be on the safe side, aswell these are quite cheap products :)
but maybe for the battery you could buy a new one to help it HERE
Im sorry if i was to no help, but good luck buddy! :) Happy fixing ;)
iPhone 6 Battery Bild
Produkt
iPhone 6 Battery
$29.99
iPhone 6 Logic Board Antenna Flex Cable Bild
Produkt
$9.99
iPhone 6 Top Left Antenna Bild
Produkt
$9.99
War diese Antwort hilfreich?
Bewertung 0
I had the same problem, if the Bluetooth wheel is spinning as well and in settings under wifi address it says NA you'll need to replace you wifi chip, YouTube how to replace iPhone 6 wifi chip and that tell you how to do it, however it requires soldering skills and a lot of effort, best bet if you inexperienced is to take it to a repair shop tell them the problem and get it done there
Hope I helped
Regards
Lucas
Bewertung 0
Antwort hinzufügen
nickmaciel2002 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 532
