Zum Hauptinhalt wechseln
Herausgegeben im Oktober 2008 / 2,4, 2,53, 2,66, 2,8 oder 2,93 GHz Core 2 Duo-Prozessor
376 Fragen Alle anzeigen
"Fluttering" lines on Display
The display has two 1-inch columns of lines that alternate on & off, "Fluttering," distorting the display with 1" black/white lines from the top to the bottom. The display on either side of the columns is normal in all other respects. When the iFixit window is open, and dragged across the two columns, the right hand column's fluttering is overwritten by the "Ask a question" content though the box around it, e.g., (red/yellow/green buttons, the top, blue iFixit toolbar, and the dock continue to flutter).
The left hand column continues to flutter, top to bottom.
My question: Is this a Display problem, needing a $700 display swap, or is it a Video circuit board problem, requiring Motherboard repair?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Connect to
an external display - if problem persists its the GPU (Video Chip)... if not it's in the cable/display circuit.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
+ agreed
von
It was the Graphics chip.
von
Antwort hinzufügen
jbarrick1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 1,077
