Why does my phone keep vibrating for no reason
My phone keeps vibrating usually 2 quick vibrations after one another fo no reason. This keeps happening while on standby . I have tried everything but cant seem to stop it.
Ist dies eine gute Frage?
PROBLEM SOLVED!!!!!!!!!!!!!!!!!
Settings- personal tab- accessibility- notification reminder- turn that from ON to OFF
War diese Antwort hilfreich?
Excellent ! Well done !
so helpful. this solved my problem. thank you thank you !!! no more annoying alerts :)
Problem solved! Thank you! I tried everything, this worked!
I can't even find personal tab (phone driving me mad)
Thank you so much brother...I by mistake turned on the notification reminder for which cell used to vibrate each 1 min apart...Your answer was helpful to me
The Vibration Setting for Your Apps can be inflicting the matter. ... Most apps have settings for badges, sounds, banners, and alerts. If any of that area unit transitioned, your phone would possibly react thereto by moving. you'll be able to check on the standing of your apps by reaching Settings and so Notification Center.
i have tried everything no result please stop my..mobile from vibrating thankq
still vibrating kindly help thankq
Your phone may vibrate for various reasons, such as incoming notifications, system updates, virus infections, or hardware problems. To address the issue, you can try adjusting your notification settings, scanning for malware using antivirus software, or taking your phone to a repair shop if there's a hardware problem with the vibration motor. In addition, you can use a Phone Vibration Test tool to diagnose and troubleshoot the vibration issue. If all else fails, resetting your phone to factory settings may be a last resort option, but remember to back up any essential data before doing so.
It was none of the many fixes mentioned for me. I ran the gamut! I just accessed the icons at the very top of the phone where you see the time and saw my sound icon was off. As soon as I turned it back on end of problem. And no annoying notification sounds either.
I even tried that plus turned on did and it STILL vibrates like a notification would every few seconds. I hate this
Did you see if the sound icon showed off when you slid down the screen from the top? It solved it for me.
i have followed all your instructions but there is no result thankq
i have bee having the same issues also.. After a little bit of digging i found this:
Settings -> Sounds and Vibrations -> Vibration intensity -> Notifications
For me the above was at "50%" turned it off and it seems to have resolved my issue.
Just wish i knew which application is triggering the vibrate when I have no notifications!
my mobile is vibrating oftr i tried following your instructions no result stl vibrating help thankq
Look up "charging sounds and vibration" and shut that off. Since all these phones are different it is hard to say how to get there. I did <settings><sound><advanced>.
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 103
Insgesamt: 682,654
87 Kommentare
Hello, Could you give a bit more detail? how often, while sitting on something or your pocket, have you tried to turn vibrate off , is resetting the phone an option?
von Goulithum
Found my own solution i did remove the battery cleaned the contacts and put out hte micro SD card put it back in and started it, the buzzing went off. might be so the SD card was not 100% in contact. :) did also remove manually all updates and forced push services for updates on the android os.. that is just stupid takes up too much space on the little phone ;).
von silverpil77
Just reset android 3 or 4 times and it works fine
von cody kamminga
hi guys my phone do the same.
von emmanuel Bathusi
my phone has been doing the same recently. i recently reset it. now we wait.
von escrossley100
82 weitere Kommentare anzeigen
