Zum Hauptinhalt wechseln
The 7" version of Amazon's new high-end tablet series, released in October, 2013. Model C9R6QM.
55 Fragen Alle anzeigen
Frage geschlossen
Kindle Fire HDX 7inch LCD Replacement Problem
I recently replacement my Kindle Fire HDX LCD but after replacement you can see the screen is working but it wont stay on the lcd screen is on in the back ground but you cant see the display unless you press the power button, then the screen flicks on and off.
Any advice?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It is possible that your digitizer ribbon cable connector has come loose, or was not properly plugged back in at the time you reassembled your Kindle. This is a common problem because of the poor layout and design of the cable assemblies.
If the digitizer is disconnected, then the LCD will come on when you press power, but it will go off a few seconds later since you will not be able to swipe the screen to 'unlock' the device from the power on screen.
The solution would be to reopen the Kindle (i.e., remove the back cover) and properly re-seat the digitizer ribbon cable plug. This is the plug on the end of the long narrow ribbon which is folded over and held down by the mid-frame chassis.
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 128
