Zum Hauptinhalt wechseln
2.0GHz, 2.3GHz, oder 2.6GHz quad-core Intel Core i7 Prozessor (mit Turbo Boost bis zu 3,8GHz) mit 6MB geteiltem L3 Cache.
580 Fragen Alle anzeigen
Grey strip on the screen
Since few days now, there is sometimes a grey strip which appears on my screen randomly. Here is the picture of the problem.
The strip seems to appear/disappear when I move the screen. It can totally disappear for days and come back again.
I'm not a hardware expert but it seems to be a problem with the connector between the body and the screen. Do you think that it's possible to fix it manually without spend a lot of money in a Apple Store?
I'm a bit worried that the problem will be worse in the future...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
Can you give us the last four digits of your systems serial number so we can correctly identify your system.
von
The last four digits: FD56.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I've got good news and bad news ...
The good is this is something you can fix!
The bad, it's going to be expensive as the display its self is damaged.
What likely happened is you either banged the system or something heavy sat on the lid damaging the display. Unlike older displays the newer systems have thinner screens so they bend vs crack. In this case the connections on the back of the LCD panel have come loose (often called a tab error) so the driver logic and the connection onto the main logic board is damaged.
Here's the IFIXIT guide for your system: MacBook Pro (15 Zoll, Ende 2013, Retina Display) Displayeinheit austauschen. The part is about $500 U.S.
Update >> 8/16/15
You may want to review this IFIXIT teardown: MacBook Pro Retina Display Teardown. Replacing the cable is a big job as well. But given your symptoms I wouldn't suspect it.
Unlike the older LVDS signaling the signaling the display uses here doesn't distort with stripes or other colorful artifacts when the cable is damaged. The issue is now no signal or dropped signal if the cable is damaged. Unlike the older non Retina models I haven't see any damaged cables without it being a bang or liquid damage as Apple improved how the cable is routed.
Given the new info that you encountered the issue during heavy game play when the system got over heated I'm wondering if you have a graphics logic issue. In this model the CPU has the graphics logic would would mean the logic board is bad. But, that can't explain the movement of the screen cutting the image in & out (grey bar) that is the symptom of a damaged display.
MacBook Pro 15" Retina Display Mid 2012 Bild
Anleitung
Schwierigkeitsgrad:
Mittel
MacBook Pro 15" Retina Display Late 2013 Displayeinheit Bild
Anleitung
Schwierigkeitsgrad:
Mittel
1 - 2 hours
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
Corrected guide info.
von
I was wondering if it’s this part which is damaged because I never put something on the screen. I suggest that the problem appeared after that the computer was really hot (because of a game I was playing). Plus, the grey strip appears only if I move the screen by pushing the left part of the screen.
von
Antwort hinzufügen
gaetanm wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 29
Insgesamt: 12,824
