Zum Hauptinhalt wechseln
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 Fragen Alle anzeigen
Why does my Xbox 360 go from green light to solid red?
When I start Xbox 360 S, the light goes green for a few seconds and then goes to a red dot in the center. I replaced the power cord, still get the same result. I removed and replaced the hard drive, still the same. I replaced the hard drive with a new one, still the same. What could be the problem and how do I fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
1 Kommentar
Red Ring of death may be only fixed in a shop for a expensive labor & repair fee with the part !!! Unless you know how to harvest parts out of other consoles just getting another good used unit may be best . Just doing a reboot may not repair a red ring of death or RROD .
Missy B.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
HogsTooth13, seems to be the RDOD (Red Dot of Death;-)Since it is most like not under warranty anymore, check the optical drive. Apparently it can cause the RDOD. Also check Youtube for some decent explanations. This video shows one more trick you can try. If none of that works, open your console and clean the airvents properly of all collected dust and debris, change the thermal paste and try, or consider some heat to the flip chip (very temporary fix). Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Thanks, oldturkey03 I'll give it a go and hope for the best.
von
Sell it for parts on ebay for $50.00 & buy another one !!! Nuff said !!!
Update (10/22/2018)
The way the trinity sets are designed they are hard as snot to take apart & pry the sides off without breaking the tabs, putting on new thermal paste & heat is just a temporary fix & you will get the RROD Red Ring Of Death again !!! Sell & get a another one !!!
Bewertung 0
Red dor showd upwpnt ho off nothing on the screehb
Bewertung 0
Antwort hinzufügen
HogsTooth13 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 72
Insgesamt: 27,952
