Zum Hauptinhalt wechseln
This page is intended for the Asus TF300T tablet released May of 2012. The Android operating system allows for users to use the tablet for multiple tasks.
19 Fragen Alle anzeigen
Frage geschlossen
How to determine Digitizer p/n
Hi all,
I have a friend's Asus TF300T where the touch screen is not working. He had got it replaced from a local shop when it was broken last year, since then it is not working. As far as I can find out the reasons could be:
1. Faulty digitizer/cable
2. wrong digitizer part installed (i.e. G03 instead of G01)
3. Faulty daughter board
4. burnt coil (mentioned in a post on iFixit)
I cannot find any sight of a burnt coil on the board... so I'll rule that out. How can I determine that the tech at the shop did not install a wrong model... since I don't think he'd have kept the old broken screen, so I cannot see the original sticker on the part. Any way to confirm which digitizer model was originally installed. I'll keep the daughter board option for the last... but first I'd try changing the digitizer.
regards
Alok
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The digitizer part number is written on the digitizer's cable. If you have the wrong version, then you can update the digitizers firmware.
These are the instructions from xda forums:
2. Root your device
2. Get the firmware https://github.com/dasunsrule32/prop...0...
3. Get it into the device:
adb push 02-3011-4820.ekt /data/local/tmp
4. Get yourself into the device:
adb shell
su
5. Delete touch firmware. After firmware update and reboot the device may update the firmware back to whatever is in the firmware folder which is the wrong firmware. It will kill the ic ability to update the firmware again. <---HELP NEEDED
In the shell:
rm /system/etc/firmware/touch *.etk
6. Update firmware:
touch_fw_update -u /data/local/tmp/02-3011-4820.ekt
I used Kingo to get root on mine.
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 812
