Wow! This question was hiding!
Its a bit late for fandeimac sadly ;-{ @michael niedzwiadek thanks for finding it!
So here’s the deal! Here’s the breakdown on the LED’s
Here's a breakdown of the onboard diagnostic LED's:
LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
I have same problem but my 1 led is on, trying to remove battery and put it back, replaced UPS and still same , power Botton works, what else can it be done to diagnose problem , I have 3 iMacs acting same way late 2012
von michael niedzwiadek
