Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Help itunes error 9
I can not Restore my iphone 6 due to an error 9. What does error 9 means and what i have to do to make it. NEED SOME HELP PLEASE.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
I believe that error 9 relates to some kind of fault with the internal storage.
No easy fix available.
Provided you haven't done anything to invalidate your warranty with Apple - get it back top them quick. They should see you right, and will likely give you a replacement.
War diese Antwort hilfreich?
Bewertung 0
Error (9) can me a multitude of different things. My error (9) was because of corrosion on the lcd flex cables that wouldn't allow the phone to boot, therefore I couldn't restore it. But when I unplugged the LCD completely I could get it to fully restore. Now my iPhone works, I just had to use isopropyl alcohol to clean all the corrosion off the PCD flex cable connectors. Sorry if I am bad at explaining im 16.
Bewertung 0
1 Kommentar:
Something similar myself.. I disconnected the rear facing camera whilst restoring and it worked absolutely fine.
von
Antwort hinzufügen
Papo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 924
