Zum Hauptinhalt wechseln
Vierte iPad Generation, erhältlich seit dem 2. November 2012 mit 16, 32 oder 64 GB Speicherkapazität. Modellnummerb A1458.
218 Fragen Alle anzeigen
How to fix ipad 4 wifi digitizer problems
how to fix ipad 4 wifi digitiser problem i bought this part : iPad 4 Screen Digitizer Assembly
so how do i fix it do i have to do anything diffrent or should i just follow this guide iPad 4 Wi-Fi Front Panel Austausch>?
iPad 4 Screen Digitizer Assembly Bild
Produkt
$39.99
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
I have done 3 of these, just follow the instructions; Pre-read instructions first. Make sure you understand them fully. Take your time, heat the warmer often and WEAR SAFETY GOGGLES: glass flies everywhere when it cracks.
Before removing any of the protective plastic coverings (inside and out) and the adhesive backing pre-test. As an Apple Tech - the white lines on the digitizer should not be visible when fully inserted into the connector.
Place the LCD in-place with screws, then gently place the digitizer on top of it. Turn it on and make sure all corners, center bottom, etc works properly. test cameras, microphone and speakers, and Wifi, buttons, volumes, etc.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
manazir hussain wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 154
