(NEW Method ) Recovering from bootloop/soft-brick. (with Contributors) for Huawei
Download au_temp.cfg (https://www.dropbox.com/s/2nr9cafmfr5qgw...)
Download Stock Rom (compatible android firmware on manufactures website www.huaweidevice.com )
Take out your sdcard from your device, and with an sdcard card adapter, connect to your PC, please do the following on your computer.
(Optional) Format SD Card)
1. Extract Stock Rom to root of SDCard.
2. Rxtract and copy au_temp.cfg into dload folder.
3. Make sure you have au_temp.cfg and UPDATE.app in your 'dload' folder.
4. Disconnect adapter.
5. Make sure your phone is switched off (Just to be safe, take out battery)
6. Insert SDcard into device.
7. Turn on device.
8. Recovery will autostart update process.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
4
6 Kommentare
Hi. My phones battery was flat, it switched off, showed a flashing red lightning sign and then went blank. It won't charge or boot up. It has a red flashing light. How do I get it to charge or switch on?
von Andrea Draper
I dont have a wipe/factory reset option and idk why? Instead it says for me to download a new recovery package via wifi.... Idk how pls help.
von Boris Nikolic
i was trying to find where the battery was located and found out it was the board,i put it back in place with panic and tried to turn on, it only showed the sign and turned off and i tried to plug it in with a adapter and didnt show charging sign,please help
von yere
I can't switch on my Huawei p8 lite
von Layla alhargan
I have a problem related to my mobile huawei p8 lite that its just stuck on 5% during installing update and my power button also not works
What to do plz help
von sadianaqi11
1 weiteren Kommentar anzeigen
