Zum Hauptinhalt wechseln
Reparaturanleitungen für Computer, die über kein integriertes Display verfügen und für den stationären Gebrauch gedacht sind.
2133 Fragen Alle anzeigen
Windows won't start normally
Suddenly, Windows7 won't start and I can't figure out the cause.
Symptoms:
- System boots, it reaches the welcome screen where message "Please wait" is displayed.
- After a few tens of seconds the screen turns black
- After a few tens of seconds with the black screen, it goes back to the welcome screen displaying same message, and then it goes to the black screen again.
This cycle repeats maybe 10 times or more, then it reboots, and when the welcome screen is reached, the following message is displayed:
"The System Event Notification Service failed the logon.
The remote procedure call failed and did not execute."
I unplugged all peripherals and USB devices, including printer and mouse and tried again, but same result.
But in Safe Mode, it starts without problems.
Where should I look to figure out the problem..?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Login in Safe Mode and open the Event Viewer to check for errors. Probably the problem comes from a software that you have install.
If you can't find anything in the Event Viewer start to uninstall softwares with Latest Date install.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
Thank u very much
von
No problem ;)
von
maybe windows update erorr. You can login with Safe Mode and restore early times.
Bewertung 2
Antwort hinzufügen
Ash Ketchum wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 144
