Zum Hauptinhalt wechseln
24-Zoll-Display; Integrierte iSight-Kamera, Mikrofon und Lautsprecher; 1920x1200 Auflösung. Erschienen im Oktober 2008, identifizierbar durch die Modellnummer A1267.
Common Logic board burn spot?
Hello
My cinema display started smelling weird and then shut down. I opened it and found the problem to be a burned spot on the logic board. No problem I'll just replace the logic board and then I can use it again.
So I was browsing for a new board when I saw a dutch thread with someones logic board also burned. But the weird thing is that the burn is at the exact same place.
Does anyone have had a problem with a burned board?
Ist dies eine gute Frage?
Bewertung 4
2 Kommentare:
Lukas Guy, it might help if you add some images to your question. That will allow everybody to see where the board gets damaged
von
Hi Lukas Guy, I have a Apple Cinema with probably the same issue. How did you replace this part? Where can i buy this part?
Gr. Vincent (from Holland as well)
von
Einen Kommentar hinzufügen
1 Antwort
Lukas Guy, that looks like the LED driver. It is most likely a "common" failure if you have a short within the backlight circuitry. Any short there would take out that driver. I would suspect the primary offender would be the LCD connector.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Lukas Guy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 2,799
