Zum Hauptinhalt wechseln
Eine TV Spielkonsole von Sony Entertainment, auch bekannt als PS4. Sie wurde am 20. Februar 2013 angekündigt und kam am 15. November 2013 auf den Markt.
1697 Fragen Alle anzeigen
Frage geschlossen
Ps4 audio but no video
Hi, my playstation get hdmi port damage , I replace the port, when I turn on the console it seems to work, I can hear the audio but shows no video, I check the parts near the hdmi chip and there are tree components, 2 capacitors and the third one don't know what it is test it with multimeter and no readings on 3 components looks like they are open, I wish to know what are the values of the capacitors and the third part, if you have any suggestion I will be grateful .
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
A pic would be helpful to help us help you figure this out. It's most likely just that one or more of the hdmi pins are not soldered fully. A pic of those pins would be helpful as well.
von
Ok here is a pic of where the parts are installed later be posting the hdmi port
http://s9.postimg.org/4mocuigqn/image.jp...
von
Héroe is the pic of the hdmi port
http://s4.postimg.org/iv5juxogt/image.jp...
von
The pic is not clear enough to see whether the pins are soldered correctly. Any chance you could get a clear pic of it?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
They don't test like resistors and they don't have the markings of diodes. I'm guessing they are capacitors. The 2 larger ones show 100 nF and the black one shows .026 nF. This is in circuit though so those readings may not show the actual values.
There may be someone else on ifixit who knows more about these components that can chime in if needed.
I can take them off of one of our junk boards and just send them to you if you want to just buy some from us.
I hope this helps!
War diese Antwort hilfreich?
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,096
