Why my CPU fans got loud noise like spin very fast?
i suspect the motherboard got problem, since sometime able on pc but sometime also cannot the fan sometime very loud sometime not. . . any idea ? just wanted to reconfirm the problem
Ist dies eine gute Frage?
4 Kommentare
i got the same problem. My HP desktop has all its fans spinning so fast at startup, nothing on display! I unplugged everything in the system unit, cleaned all the components and blew out all dust. But problem still recurs. But i realized something when i was troubleshooting, that when i dont plug in the CPU power from the power supply unit and power it on, i get 4 short beeps, but again while its beeping, the fans are not spinning so fast this time. Any suggestions guys?
von Lexx Tito
CPU fans got loud noise like spin very fast? because of little bit ram issue and mostly due to bad CPU socket,
von Altaf Hussain
I had a same problem. The issue may be the fan with heat-distributing-socket. The reason is the screws to fix this fan, some of which may be losing or broken, to make this fan not working properly. The touching surface between the CPU and the fan becomes not tie to make temp on CPU too high, to make heating sensor output high voltage to rotate fan high speed. Try to find a same fan to replace the current fan, the problem is solved.
von Ying Bai
please update the bios firmware and all drivers it will be ok
von Abrar
