Internet service not working
I'm not able to access Internet even when my connection is good...on the new windows 10 I'm not able to utilize my search engine go pull up google or any other Web sites
Ist dies eine gute Frage?
If you have recently upgraded to Windows 10, you may need to plug in the computer to the router or gateway box by an Ethernet cable.
The Ethernet cable should look like this,
Connect it to the end of the router and into the connector on your computer.
Then click on the search icon right next to the start button, and search for 'Windows Update' and check, download, and install all new updates.
You will want to make sure you also restarted your computer after checking for updates.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 73
3 Kommentare
you likely need to update your LAN drivers
von Jimfixer
That's didn't work. ...still not able to use internet. When I click on the explore icon it kicks me off
von Shayaria Richardson
If none of these helped, and you know that your connected to the router with Ethernet, your ISP may be at fault. Try contacting them for help with your internet.
von Nickoplier
