Zum Hauptinhalt wechseln
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
136 Fragen Alle anzeigen
How do I recover the phone internal memory after replacing new screen
My son threw the tab on the floor in rage and the whole screen cracked into bits but the touch was still working.. Before this my phone too cracked and I gave it to renew the screen of it.. But after I renewed it all the apps and files were not there it was like a new one with only pre-installed apps, now I gave my tab for a renewal.. I don't know how am I gng to get all my files back.. I have more than 500 pics 15 odd videos and 30 audios and many important files in it.. I need them recovered immediately after the renewal.. Anyone who can help me if u know how to get my internal memory from the tab plz reply
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
If the tablet was "renewed" (ie: reset) then all data is now lost. Data backup should be done BEFORE any renewing or resetting. You could possibly recover files with programs but it is unlikely since all memory on these sort of devices are flash memory.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Your info is lost . some can be recovered as long as you dont overwrite it Zar.x is a program that will reproduce all files that are on a fash drive as long as you dont load anything on top. so dont use the tablet till you run the recovery program
http://www.z-a-recovery.com/
Hope this helps
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
BTW everything ever written to the drive will end up in the file you'll have to sort through a lot of info to find what you want . this program is run from your computer and you need to connect your tablet to your computer to do the work
von
Actually, I myself have also had such a problem. Later, I learn that internal memory does not mount as a drive like external memory does and that usually Android recovery tools can only restore things from mounted memory location—SD Card. But, Android Data Recovery can easily solve and restore data from Android internal memory. My phone is Samsung Galaxy S6, based on Android 4.4 though I assume this should work for most Android phones of most Android OS's, including Android 4.4 and 5.0.
Requirements:
1.Android Data Recovery, which is a professional program designed for retrieving lost contacts, messages, WhatsApp history, pictures, music and videos from Android internal memory and also external memory.
2.A USB cable.
3.A computer (This app also has a version for mac. Since the process is more or less the same as in Win7, I will only do it under Windows.)
Bewertung 1
Antwort hinzufügen
Imthiaz Latiff wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 263
