Zum Hauptinhalt wechseln
This tablet is 9.09" high, 6.21" wide, 0.34" thin, and was released on October 2nd, 2011. Its Model Number is GT-P7310.
7 Fragen Alle anzeigen
Frage geschlossen
tablet wont accept charge
Hi, I need help my daughter tablet dead & wont accept charge, so I open back cover disconnect the battery & reconnect but no luck, I measure battery voltage 3 volts
next step I did was disconnect battery & direct charging the battery for four hours ( I create modified one with alligator clips so that I can access to the positive & negative of the battery) check battery voltage 3.7, I let it charge for 2 more hours to make at least 4 volts but it stay at 3.7 volts,
I removed the charger and re connect the battery, switch power button on and galaxy tab display but its freeze in this mode and logic board start heating I can feel abnormal heat even in the display screen. I off the unit and did the normal charge & battery icon display but it wont accept charge . the final thing I check was remove battery connection and put the charger in normal way to check if the logic board still heating & its not, check battery voltage to terminal connecting to the battery 4.2 volt
I conclude that when my battery down to 3.2 volts it will totally dead
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Jhun Banton, this could be caused by a bad battery (even so it charges does not mean it will hold a charge) as well as a bad charging connector or a failed power management IC on the logic board. I would suggest that you start with the simpler things which is a battery replacement.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks oldturkey I will try to swap battery first before I buy a new one. I hope its only a battery problem. but I'm worried about the ic power management its too hot. Thanks anyway I will let you know after I try the battery first.
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 755
