Zum Hauptinhalt wechseln
The Sony Ericsson Xperia Play is the first Android handset to feature a controller with PlayStation controls.
hard reset sony ericson experia x10i
master code for sony ericson xperia x10i
Ist dies eine gute Frage?
Bewertung 35
4 Kommentare
Hloo guys I forgot my secret answer Wat can I do pliz help me
von
das funktioniert nicht
von
Yes me be master code need
von
me lo regalarom con átron
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Hello,
Best of my knowledge, you won't be able to find master code for Sony E X play, but you can try below steps to reset your phone to factory default.
Option 1 – Hard reset Xperia X10 using hardware buttons
1. Unlock the screen then press and hold the Power button for two seconds. Select the Power off option. If the phone won’t turn off, pull and replace the battery.
2. Hold the Left and Right buttons located under the display.
3. Press and release the Power button while continuing to hold the Left and Right buttons until instructions appear.
4. Follow the instructions on the screen.
Option 2 – Hard reset Xperia X10 using software
1. From the Home screen press Menu and select Settings, or tap the application slider and select Settings.
2. Select Privacy.
3. Tap Factory data reset.
4. Select Reset phone.
5. Select Yes to confirm the hard reset.
The Sony Ericsson Xperia X10 will then go through the process of formatting the memory. Wait for it to restart and factory default settings will be restored.
War diese Antwort hilfreich?
Bewertung 9
3 Kommentare:
please resetting my Sony Ericsson x10i with the two action bottons under the sreen and power botton is not working. Please is there any other way to hard reset my device.Help me please.
von
Am facing the same problem how can i get your assistance
von
sure. how may i help you?
von
tabliiq waa ok 0634103233
Bewertung 3
Guys if you are suffering over the same problem please try a technician just because i have triede several times but all the options has failed.
Bewertung 2
2 Kommentare:
yes its true some sony not support hard reset
von
my phone is not support to hard reset
von
Antwort hinzufügen
stanley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 36
Insgesamt: 32,203
