Zum Hauptinhalt wechseln
Reparaturinformationen für die Samsung Galaxy Tab Serie von Android Tablets.
Wont charge, keeps flashing and disappering?
My Samsung Galaxy 4 tablet wont charge. I plugged it in and the battery sign appears but it wont start charging. It either freezes on the battery sign or the sign appears and disappears. The tablet is off. Wont turn on. When I try to turn it on, it turns off quickly and the battery sign appears.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 35
38 Kommentare
now the chagrining animation wont show up
von
Jojo, what model of the Galaxy 4 is your tablet?
von
Um model? all I know is that its a Samsung galaxy 4 tablet. I tried a phone charger again and it is starting to charge but the screen keeps flashing black and when I turn it on it automatically turns off. should I just let it charge for a while and then reset it when it turns on?
von
why does a phone charger work but now the one that's made for it?
von
What size is the screen? The Tab 4 comes in a 7" and a 10.1" version?
von
33 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
15 Antworten
Gewählte Lösung
Have you tried a different cable or try moving the connection around carefully to see if the charging port is broken you can also try a reset. Power button and volume down button at the same time till it says its resetting
War diese Antwort hilfreich?
Bewertung 27
23 Kommentare:
I tried multiple charging cables. I even bought a new one. I also tried the reset option and it won't work :( is my tablet officially garbage?
von
How old is the tablet it does sound like its time for a new battery
von
My new cell have 4 virus, what I do
von
I'm having this problem only with two replacement batteries I ordered. Is this a known issue? Can it be fixed or is it time for a return?
von
I have a galaxy tab I'm repairing for a client. I had the same issue as above with the power flickering and then shutting off. I tried a new micro cable and it fixed the issue. Thanks for the suggestion as I didn't realize this cable was damaged.
von
18 weitere Kommentare anzeigen
Hilfreichste Antwort
Firstly, the battery is not holding a sufficient charge to boot because the LCD screen is constantly turning on. This causes a tremendous drain on the battery for a split second, if your battery is completely dis-charged like mine then you will never get ample charge into the battery for it to turn on hence why the screen keeps failing.
1. Open the back cover.
2. You will see 3x vertical ribbon cables. Carefully remove the on on the right, it is marked LCD (Convenient)
3. Plug your charger in and leave it to charge for at least 8 hours. (Use the wall socket adapter, it produced more current than a USB port on your computer) Now that the battery is not being drained constantly by the display the battery will have a chance to get some juice into it.
4. After you have left it to charge for some time unplug your charger (Crucial) , re-insert the ribbon cable for the LCD you removed making sure that it is in all the way so that the lines on the ribbon and the board are aligned.
5. Power on.
If it boots great. If not it may be time to purchase and replace the battery ($25 on eBay) and make sure that your charger has enough power to keep it charged and at 100% while in use. Beware of leaving any Li-Ion battery fully discharged for a long period
Good luck!
Bewertung 51
30 Kommentare:
Same problem is with my Samsung but my phone has some battery left. It was not charging , so I tried to charge it through switching it off and then it's kept flashing and disappearing. So, I switched it on and then i connected charger slowly, it's started charging.
And That's meaning charging port of mobile is broken.
von
This worked for me! I accidentally unplugged the touch screen ribbon though instead of the LCD. Looks like my battery was/is shot and was near zero %. I imagine it only has a few charges left on it before it's completely toast. Will eventually replace the battery.
Thanks Gavin!
von
I can't do that with my samsung tab because you can't open up mines help what can I do
von
This worked for me. I had replaced charging port but still wouldn't charge. This did the trick. Keep it charged from now on. Thanks Gavin.
von
I have a samung tab 18.4 and when the wall charger is plugged in, it continues to beep on and off, and the charging display also goes on and off. I bought a new charger, and problem still exists. I called Samsung help desk and they told me to take it to best buy and let them look at it. You pay all this money and nobody there knows or cares that your frustrated.
von
25 weitere Kommentare anzeigen
I had the same issue. This might sound weird but this is how I solved it. I tried all the different button combinations didn't work. While trying the combinations I realised the tablet felt cold. Kept the tablet against my body while charging for about half a hour while watching a movie on laptop. Body heat seemed to have warmed it enough to start charging. Suppose you could try other warming methods.
Bewertung 12
14 Kommentare:
Well this would explain alot. I put my tablet on my window cill and the air is freezing outside. Im quite stupid. Hopefully this works!! Thanks
von
this worked for me.... only took 10 minutes. You are a lifesaver
von
I can't believe this worked. Lol thanks!
von
Hair dryer... 5 minutes!
von
worked for me too thnx a lot for the advise
von
9 weitere Kommentare anzeigen
Anyone tried the volume down + power button hold down trick for 5-10 seconds?
Bewertung 11
10 Kommentare:
Yes, I did try that and the on screen came on. However, it still won't charge or power up. My screen continues to flash on and off.
von
Thank you! It's so good that people bother to give solutions. Thanks!
von
My new galaxy 8 is default
von
I found out on my Samsung galaxy tab 2 10.1. That the hard drive is bad so I have to get a new mother board since the hd is integrated onto the MB. Ugh
von
if you're charging your tablet with your computer it will cause that to happen too, switch to a normal charging source
von
Right now it sounds like you are having battery issues. what is the voltage/amperage of the phone charger you are using? If you do not have that written on the charger, what model is the charger?
Bewertung 3
1 Kommentar:
You just said it right on the dot. It's a battery shortage. Both of my Samasungs did it and I refuse to get another one. They are both from Sprint bc I was eligible to get "Free tablets" and both did it within less than 3 months. It's aggravating and for whatever reason it's all android or Samsung products that always had issues with batteries bc my LGs and Samsung phones had the same issues with the batteries. I honestly think and believe when they say you're getting a new phone and tablet they give you refurbished ones bc my "brand new iPhone 6s I got from the actual store physically already had a dent on the back and th tablet had a scratch but they claimed it was brand new. So why am I having a software issue with my iPhone 6s if it's brand new? There're all a bunch of crock...thinking of switching providers now
von
The last time I used the tablet was about 4 years ago. Needless to say, the battery was completely drained. I plugged it into a charging cable connected to an iPhone 2.1A charger but the display just kept on flashing. Hmm. I then connected it to a wall charger with the same result. I was 100% convinced it had to do with the power supply not being strong enough. The 2.1A output may not be true 2.1A. I then switched to a portable battery charger with 5V 2.1A output and voila, the Samsung Tablet is now charging as it should. The display stopped flashing, and it shows a battery with a small green line at the bottom indicating it is charging.
Bewertung 2
I had the same problems. Wouldn't charge, screen kept turning itself off. I pulled the back off and disconnected the battery and could see that 3 of the 6 copper teeth on the motherboard (that the battery connector plugs into) had come off the motherboard and stuck themselves to the connector. No way to remove them without destroying them so I stacked two pieces of cutup old credit on top of the battery connector and snapped the cover back on. It's pretty tight in there already, so the additional pressure was enough to keep the connector pressed hard into the motherboard and the power connection complete. No more problems. Won't last forever, but it'll do the trick until I can sort something else out.
Bewertung 1
2 Kommentare:
Thanks Byron, your solution works for me.
von
Byron, you're a genius! I had the same problem, battery charging icon blinking and not charging. I checked the battery connectors and realised for some reason that they seemed to be pushed back into the phone more than was necessary. Seems not all were making solid contact with the battery and hence the blinking. I simply pushed them out gently, using a pin, put back the battery and voilà, phone is now functioning 100% . All this after buying different chargers and changing batteries countless times!! Thanks again for your insight!!
von
Warming works! I placed it under my leg whole in bed for 20 minutes!
Bewertung 1
The Battery connector might be loose, open the back cover and Solder it to make sure it is connected properly...
If the problem still persist then change the battery...
It should work...
Good Luck...
Bewertung 0
My Samsung tab e wouldn't charge was going take back off and unplug charging port but before I did I simply turned off tablet plugged in charger and it charged in no time
Bewertung 0
Try cleaning the charger port with a paperclip- pick out any dust bunnies in there, and if needed carefully scrape the metal connectors. That worked for me.
Bewertung 0
I have a Samsung Tab a10.1 and after not using it for a while and putting it to charge, the lightning/charging symbol came up but after a few seconds the screen started to flicker a lot. I tried two cables. Both connected to the USB front of my PC. Turns out it worked when I used the normal power plug and into the power outlet.
Bewertung 0
I tried the thing were you unplug the screen and that worked… when it died it had the same problem, I tried 8 hours first (it worked the first time) and the second time I tried 5 hours (worked after it died) and now it's staying on! Hope this helps!
Bewertung 0
The battery does not receive the charge. Someone tried to heat the battery surface with a hair dryer by about 10 minutes. This worked for me. You need to heat the battery. Then plug the charge.
Bewertung 0
1 Kommentar:
It is a very dangerous job Bro :)
von
conclusion tools - Heat the back of ur device using any method comfortable for u for abt 5-10 minutes this should warm up the battery meaning it can give more strength, then put it into charge straight from the wall, if this does not work it means your tablet needs stronger power because it is fully drained and is getting power than using it on the screen so put it into a 5V2.1A portable charger using only one of the USB ports wait a bit, if this does not work than you are going to have to disconnect the screen from the battery from the back this is so that the power can go straight to the battery. there are useful instructions before me..take a look at those i hope i was useful i'm sorry if i yapped on a bit :), had the same problem and was very frustrating, i came down to all the conclusions so it could be less hard for you guys :)
Bewertung 0
1 Kommentar:
Hey man, heated my tab s6 lite for about 10 min, no changes, also ,i can't talk off the back dince it's built in. Any tips??
von
Antwort hinzufügen
Jojo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 19
Letzte 7 Tage: 112
Letzte 30 Tage: 526
Insgesamt: 459,337
