How do I fix a stuck lens?
My camera lens is stuck. Is there any way I can fix this on my own?
Ist dies eine gute Frage?
Stuck lenses are a common problem. Usually, it's caused by sand or dirt inside the mechanism, or the lens has been dropped. Sometimes, you can't repair it yourself and you will need to take it into a repair shop. However, you can first follow the steps in this guide to see if you can fix it yourself.
War diese Antwort hilfreich?
If you r lesn has fallen and as a result is stuck, I have found on YT a totrial that can help. It has worked for me and saved me quite an expensive repair. I ahve copied teh title and link to the video below, good luck:
HOW TO Repair A DSLR Camera Lens That Is Crooked And Jammed After Being Dropped #DIY #Repair
Letzte 24 Stunden: 4
Letzte 7 Tage: 26
Letzte 30 Tage: 125
Insgesamt: 42,326
1 Kommentar
I cleaned it with paper worked great
von Andrew Howell
