What can I do if my tablet keeps restarting?
My tablet keeps restarting until it is out of charge. How to fix it?
Ist dies eine gute Frage?
There are a number of potential causes for a smartphone or tablet repeatedly and unpredictably restarting itself. Please follow the steps below to troubleshoot this problem with your device.
Download the latest software update
The current software update for your device may fix any bug(s) that are causing the restarts. Follow these steps to download the latest software update for your device. Note: the steps required for your specific device may vary slightly from the following.
Make sure your device first has a WiFi connection and then on your device go to Settings > About Device > Software Update and then touch Update.
Remove the external SD card
If your device contains an external SD card please make sure your device is powered off, remove the external SD card and then power on the device again and see if any further unexpected restarts occur while your external SD card is outside the device.
If your device works fine without the SD card it is very likely the SD card is at fault. Delete all software on the SD card and see if your device works with the SD card after you have wiped it of data. If your smartphone or tablet still restarts unexpectedly while the empty SD card is inside it the SD card likely has a hardware fault and will need to be fixed by an engineer or replaced with a new SD card.
Perform a factory reset
A factory reset will restore your device to the state it was in when it left the factory. This means that all the changes you've made to your device and all the media you have stored in its internal memory will be wiped, so please make a backup of anything you don't wish to lose on another device, such as a PC. When you've safely made back ups of all your important data follow these steps. Note: the steps required for your specific device may vary slightly from the following.
Go to Settings > Back up and reset > Factory data reset and then touch Reset device.
War diese Antwort hilfreich?
It rounds like you have a corrupted firmware. Go to the manufactured website and download the latest firmware for your device and restore.
Have you tried turning the device off and turning it back on?
Yep, but I cannot turn if off, because it restarts again.
You might have a faulty power button. Have you checked to see if your power button has a short with a multimeter?
Not yet. I will try it when I get a multimeter. Thank you David
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 1,833
