Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Frage geschlossen
Sensor/FrontCam Flex suddenly dead after screen replacement
Hello!
I have replaced a bit over 100 iPhone 6 screens now and about 5 of them the sensor flex has just died out of nowhere!
Sometimes the proximity sensor stops working completely or if won't transmit any sound to the earpiece/receiver. Never had any problems with the camera tho.
And its not that I just place it wrong it really breaks!
Very annoying but thankfully not that common. NEVER had this problem on a 5 or 5S
Anyone know what might be the cause of this? Maybe the p-sensor is sensitive and is damaged even though I handle it with care, but the sound??
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It's the alignment of the proximity sensor most of the time also make sure the little black square piece of rubber is seated where the sensor goes.
If it still does not work u need to replace the sensor as taking it off, no matter how gentle you are will cause the problem. Remember it's a fragile flex cable
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
It is not a question about the alignment I know all la about placing. the sound really breaks.
Yes ok sensitive p-sens might break more easily but sound should still work.
I was one of the first to replace a screen here in Sweden I have done it hundreds of times after that.
von
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 94
