Zum Hauptinhalt wechseln
A sturdy tablet designed by HP for business and government use.
Can I increase hard drive capacity?
Can I increase the storage capacity of the hard drive? The initial capacity seems too small for what I need and would like to increase it.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
The eidt bade work when concted to charching divice but not work when remove from it
von
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
The ElitePad comes with 2Gb of RAM and Hard drive sizes vary from 32/64 Gb. If more space is needed it is compatible to external hard drives that can be connected to USB ports on the docking stations or the detachable keyboard.
War diese Antwort hilfreich?
Bewertung 1
You could use apps like Google Drive and Drop Box to store and access your information on a cloud system. You "expand" your memory storage and are able to access that info on other devices!
Bewertung 1
I have a 128 GB microSD card in my Elitepad 900 G1, it seems to work OK
Russ
Bewertung 1
The Elitepad has a microsd slot hidden under the cover symmetrical to the volume buttons. put a large microsd in there and you are away
Bewertung 0
No its built into the motherboard and you have a SD card slot that can go up to 64gb that's it.
Bewertung 0
Actually I used 128 MG cards n problem and reliably filled them up.
Bewertung 0
Antwort hinzufügen
Kyle Marques wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 3,817
