When your Mac has been used for a long time. If you do not clean the junk files on Mac often, your Mac's startup disk space will be filled. At this time, you only need to clean up your Mac to solve this problem. You can clean up your startup disk space based on the following ten aspects.
1. Remove old iOS backups
2. Remove iOS software updates
3. Remove unnecessary applications
4. Clean up the cache file on Mac
5. Delete unnecessary language packs
6. Delete the old iTunes library backup
7. Clean up your photo library
8. Clean up your downloads, movies, and music folders
9. Clean up your desktop
10. Empty out the trash can
If you find it difficult to clean these ones manually, you can download some Mac cleanup tools (such as my recently used iMyMac's Mac Cleaner software) to help you clean up these things.
Read More:'''Startup Disk Full on Mac, Full Solution in Here!'''
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
